AMF petro free
  • AMF petro free
    AMF or QAMF no longer makes Petro-free. I’ve been looking for something similar. Was the best solvent to clean chutes, parts, dissolve contact cement to pull off Old pit carpets. Especially interested to find a replacement to dissolve pit carpet glue. Anyone have suggestions?
    I think a heat gun will loosen contact cement and help you remove a pit carpet. You can use lane cleaner or a blue butyl cleaner on pinsetters. Home Depot sells Zep Industrial Purple as an example, but it may be no better than other cleaners of the same type. Use rubber gloves if you use it straight on tough cleaning problems. You can dilute it way down for daily cleaning. Solvent cleaners are getting harder to buy because the fumes rot your brain.
    Help-broken Part
    Greeting all.
    Thanks for looking.
    Bolton454
    Pin Damage
    Making TDM's adjustable.
    Gold Crown Masking Unit
