The PinClaw
  • The PinClaw
    Introducing...... {drum roll here}
    THE PINCLAW
    Click image for larger version  Name:	thread12.png Views:	6 Size:	1.85 MB ID:	1100549Click image for larger version  Name:	thead13.png Views:	3 Size:	1.80 MB ID:	1100550
    In this video, I was still finding the best shape for the 'Claw'. Notice the flat fingers? It dropped pins. The pictures show the final design, the 'Stranglehold'. Now I can pick up and hold pins upside-down.
    You will need to be creative with what you have. Pictured here are the simplest of materials that can be found in most of our scrap buckets.
    -1" conduit, to suit the length you desire. Mine is 6 foot.
    -1 'T' bracket
    -A good bit of cable to run up the center
    -Some flat stock. Mine is made from an old file-folder-holder, like in an old desk.
    -Heat-shrink tubing to protect the pins. (and aids in 'getting a grip')
    - baby spring, origins... unknown.
    -1 broken, bent, or otherwise junk 070-006-051 (Brunswick guys, you're on your own here. )
    - little fiddly bits to bodge it all together.
    We'll call this one version 1.1
    There is no licence fee (if you start makin' 1000's of them, $1 each please ).
    PinCup's gift to you.
    Please post your version of 'The PinClaw'
    *Goals ver 1.2*
    } rugged! I used the crap outa mine. Top-knots in my cable coming loose.
    } fast to retrieve pins
    } dexterity in spotting/gripping pins
    } good reach
    } light weight
    } speeds up 'stop recovery time'
    Let's see what you come up with.
    Ready?...... GO!
    PinCup.
    Originally posted by PinCup View Post
    *Goals ver 1.2*
    } good reach
    } light weight
    } ability to lock shut
    (mine is squeeze to close)
    PC
        That's brilliant, beats my broom stick with a curved hook on the end LOL
          No offence PC, but I work my ass off to not have to use that type of equipment. If needed the solid u shaped hook works ok for me.
            Originally posted by rivmike View Post
            No offence PC,
            None taken Mike, OOR and Deadwood just happen.
            We still run table wires here in Wilsonville, so a broken wire can cause re-spots.
            I'm a work smarter not harder, kinda guy. And....., being the B mechanic is boring as HELL!!!
            Looking through the scrap bucket I thought to myself,...
            PC,.... You could do something cool with that junk.
            And of course, I have to challenge y'all to come up with a better one.
            PinCup
              PC , I still run cell wires also. I have a wire connection up by the wireway where the cell wires enter that is hooked to a wire and ground. When I have a broken wire or something funky, just plug it in until the issue is solved. The good thing is my Mendes cycles the mach. if there is a new bowler up and not ten pins on the deck. So the bowlers don't have to touch anything, just wait for the extra table cycle. Works good without a chaser, when the girls are running things.
                PinCup
                B mechanic, cell wires? Wow, we have so much in common!...lol
                It's too bad you can't use smilies or avatars or pics for signatures on here, cuz what you put up for your post was perfect!
                ---yup
                  doesn't run in my family.... it Gallops!!!!
                  PC
                    PC
                    And I kick your butt at PinPong and Badminton too!
                    Supwitdat,
                    Dats jut me,
                    PC
                      Pop Pop! Where's the bubble wrap?
                      PC
                        Unless this is a standard AMF given tool..probably not... This is ours
